Activity Coefficient In Distillation Design
Posted 18 December 2012 - 12:06 PM
Posted 18 December 2012 - 02:20 PM
Posted 21 December 2012 - 05:44 AM
activity coefficient is used to determine the Psat (for non-ideal gas compound) in modified Raoult law
so how does this modified raoult's law helps in the design?
Posted 21 December 2012 - 11:07 AM
The concept of the activity coefficient is a mathematical concept that we use to try to describe the VLE of a system. A good VLE/thermodynamics course or text should describe how this is derived.
Posted 21 December 2012 - 11:56 AM
Roult's Law: yiP=xiPisat
Modified Raoult's Law: yiP = xiγiPisat
γi - activity coefficient
Posted 22 December 2012 - 01:23 AM
Among the important considerations in distillation design (maybe the most important???) is how different the vapor phase is from the liquid phase in the system. This is vapor-liquid equilibrium. In real world terms, we use quantities like y (vapor composition) vs x (liquid composition) or volatility (K value which is the ratio of y to x) or relative volatility (the ratio of the K values) to describe the VLE of a system. To design a distillation column, it is necessary to understand these properties of the VLE of the system.
Thanks!
![]() Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
Rupture Disk Tail/lateral Piping Design BasisStarted by Guest_Karthikram_* , 19 Aug 2025 |
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
