Amine Treatment Unit
Posted 20 December 2012 - 04:10 AM
I am currently modelling out an Amine treatment unit (30% MEA) in hysys as part of an NGCC power plant. Currently I am facing a few setbacks in terms of literature information particularly at the regenerator side and would greatly appreciate if anyone can supply me with the following information:
Typical Regenerator distillate pressure & temperature
Typical regenerator bottom pressure and temperature
Some relevent information
Inlet Regenerator Temperature: 93.3 deg C
Inlet Regenerator Pressure : 674 kpa
Warmest Regards,
Faizal
Posted 20 December 2012 - 11:57 PM
Cheers,
Colin
Posted 06 January 2013 - 01:33 PM
Posted 07 January 2013 - 03:19 AM
Posted 11 January 2013 - 03:00 PM
120 F in the condenser is good, too.
As an additional note, 30wt.% MEA is on the high side.
Posted 01 February 2013 - 11:19 AM
Faizal:
If you don't understand the Amine acid gas removal process, you are wasting your time trying to simulate it. Garbage in will only produce Garbage out.
Go to the Industrial Professional and the Hydrocarbon Forums where you will find a lot of threads where I have detailed, sketched, and explained in detail a lot of the Amine acid gas removal process. Additionally you should have access to (or own) the following books:
- "Gas Purification"; Kohl & Neilsen
- "Gas & Liquid Conditioning"; Robert N. Maddox
- "Gas Conditioning & Processing"; John Campbell
- "GPSA Engineering Databook"
If you need specific explanations to how the process works and how it is designed by manual calculations, go to the Students or Professional Forums and start a thread there. I will be happy to explain what ever you need regarding these processes.
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
![]() Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025 |
![]() ![]() Molecular Sieve UnitStarted by Guest_Sufy_* , 26 Feb 2025 |
