Block Bypass Streams In Htri
Posted 27 December 2012 - 02:33 AM
Posted 27 December 2012 - 01:29 PM
Posted 16 July 2013 - 10:49 AM
Hi
I have a doubt regarding stream analysis.
I designed a exchanger using HTRI and it shows B flow as 0.4, C as 0.3, A as 0.2 and E as 0.1.
And if I block A and E streams, my heat transfer comes out to be same as case with no block flows.
So, will my exchanger work with lesser B flow? And what is the significance of stream analysis if my exchanger is giving desired outlet with lesser area?
Himant
Posted 16 July 2013 - 01:19 PM
If you are using HTRI in design mode, the heat transfer will be the same for every configuration. When you specify the inlet and outlet conditions of one of the streams, there are no degrees of freedom to adjust the overall duty. Are you running HTRI in design mode? To address your specific questions, for exchangers where the tube side coefficient greatly dominates the total thermal resistance the flow path on the shell side will not significantly affect performance -- condensers are often a good example.
Posted 16 July 2013 - 10:40 PM
Thank you for your reply.
I was running HTRI in design mode. To be more clear about my case, I am attaching screenshot of my case.
I have just used water in shell and tube. Area comes out to be around 77 m2.
In this case, there is not dominance from shell side and tube side. Main problem is with the stream analysis and window and cross-flow velocities.
At this moment, I am not concerned about vibrations.
Himant
Posted 16 July 2013 - 10:43 PM
![]() Htri,Started by Guest_guoyinyanliner_* , 25 Jun 2025 |
Split The Feed Into Two Identical StreamsStarted by Guest_tomr91_* , 16 Mar 2025 |
Instantaneous Transition Between Two Streams Of FeedstockStarted by Guest_tomr91_* , 11 Mar 2025 |
![]() Isolation Requirement For Bypass Valves/ Movs.Started by Guest_shantanu.ghag_* , 15 Sep 2024 |
![]() Bypass Line Control LoopStarted by Guest_Tee2012_* , 20 Aug 2024 |
