There are three unit operations for liquid-solids separation in Aspen Plus, including HyCyc, Cfuge, and Filter.
I am working on these three unit operations. When I choose MIXCIPSD as stream class in the setup. The simulation works.
When I choose MIXCISLD as stream class in the setup. It shows error because I didn't define particle size, such as PSD. Is there any method to choose MIXCISLD for HyCyc, Cfuge, and Filter models? And I can define particle size without choosing MIXCIPSD.
Here is another question. When I choose MIXCIPSD and define PSD, some unit operations do not work, such as flash, Rstoic, and sep. I am pretty sure Flash, Rstoic, and sep can use for solid, but not for defining PSD.
It looks like a dilemma. I must define PSD to use for solid unit operations. However, I should not define PSD to use other unit operation.
Hope someone can give me some suggestion.
Thanks,
Dylan
Aspen Plus Solid Unit Operation Question
Started by shengyuanyi, Jan 06 2013 02:01 PM
aspen plus solid psd mixcipsd hycyc cfuge filter mixcisld
No replies to this topic
Posted 06 January 2013 - 02:01 PM
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
![]() Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025 |
