I am simulating absorber column using rate-based RateFrac model in aspen plus, during simiuation i want to perform parametric study e.g effect of liquid flow rate so i change flow rate from 100ml/min to 200 ml/min, it simulate well for 100ml/min but when i simulate at 200ml/min it gives error "BLOCK ABSORBER IS NOT IN MASS BALANCE", . I dont understand why this error occurs, please help me if any body has performed same kind of simulation.
Block Absorber Is Not In Mass Balance Aspen Plus
Started by ali haider, Jan 09 2013 04:30 AM
No replies to this topic
Posted 09 January 2013 - 04:30 AM
![]() Material Balance With ReactionStarted by Guest_Kentucky08_* , 30 Apr 2025 |
Scrubber(Absorber) In Apsen PlusStarted by Guest_Seonwoo_* , 20 Mar 2025 |
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
