I have mixture of HCl+SO2 in the 1:1 molar ratio and I want to separate it to manufacture sodium bisulphite (99%) from this stream in the solid form. Please help me. I owe you. Thanks.
Manufacture Of Solid Nahso3
Started by sagarnirgide1991, Jan 10 2013 06:52 AM
separation of hcl+so2 mixture
Posted 10 January 2013 - 06:52 AM
Posted 15 January 2013 - 01:14 AM
Hello. The process that you are looking for can be found in a patent described here:
http://www.google.co...s/US20100008845
There is a full pdf file that you can download. This is sufficient to educate you about the production.
I wish you well.
I wish you well.
Posted 28 March 2013 - 02:21 AM
The current status of flue gas desulfurization in our country was analyzed, and the significance of using SO2 in flue gas to prepare NaHSO3 was discussed.
![]() Solid Naoh Dissolving In WaterStarted by Guest_lak1r_* , 10 Apr 2023 |
Equilibrium Vapor Liquid Solid In Trickle Bed ReactorStarted by Guest_nannanine_* , 14 Dec 2023 |
Solid Entrainment In Vapor StreamStarted by Guest_Leotop_* , 16 Feb 2023 |
At What Temperature Does Water Evaporate When Drying A Solid ?Started by Guest_Checster_* , 30 Nov 2022 |
![]() ![]() Heat Transfer To Solid-Low Conductivity MaterialStarted by Guest_Bojan332_* , 18 Aug 2022 |
