I need help designing and optimising a crude oil distillation unit for my final year project. Any help in the form of advice, standards, books etc is welcome... Thanks in advance
Crude Distillation Tower Design
Started by bendel47, Jan 11 2013 06:21 PM
distillation multicomponent cdu refinery distillation crude distillation
Posted 11 January 2013 - 06:21 PM
Posted 12 January 2013 - 01:39 PM
I suppose you will have a given crude and break it into pseudocomponents, http://books.google....ponents&f=false '> http://books.google....ponents&f=false . And you will try to simulate the atmospheric distillation of this crude using e.g. HYSYS, or some other simulator, http://vimeo.com/29785015 '> [media]http://vimeo.com/29785015[/media] . My knowledge on the above is quite limited, others could give guidelines. But a general knowledge of petroleum processing is judged to be necessary. One starting question would be "what products this distillation column has to have".
Useful books for this purpose would be:
1. Petroleum Refinery Engineering by W. L. Nelson, 4th edition, McGraw-Hill, 1958
2. Petroleum Refinery Distillation by R. N. Watkins, 2nd edition, Gulf, 1979 (also teaching how to do calculations manually).
If your instructor can arrange a visit to a refinery after some familiarization of yours, it would be beneficial.
Note: There are 3 basic types of petroleum refineries, http://www.cheresour...rsion-refinery'> http://www.cheresources.com/invision/topic/15561-difference-between-full-conversion-and-semi-conversion-refinery.
![]() Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
Rupture Disk Tail/lateral Piping Design BasisStarted by Guest_Karthikram_* , 19 Aug 2025 |
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
