Hello Friends,
I am running two catalytic naphtha reformers for production of gasoline. And currently am injecting isopropanol to control the water-chloride ratio. Isopropanol is abit expensive and am thinking of using methanol as a cheaper alternative.
Whoever has experience in using methanol please share with me its performance on the reforming process.
Thanks.
Use Of Methanol In Reformer Moisture Control
Started by Munalizer, Jan 18 2013 07:17 AM
No replies to this topic
Posted 18 January 2013 - 07:17 AM
Parallel Control Valves Downstream Relief ScenarioStarted by Guest_pklavinsJ_* , 18 Jun 2025 |
Smr Reformer Flue Gas FlowStarted by Guest_kaidlut_* , 14 Feb 2025 |
![]() Gas Hydrate Inhibition: Calculations For Meg/methanol InjectionStarted by Guest_PYG_* , 30 Sep 2019 |
![]() Methanol Water Distillation ColumnStarted by Guest_Kakashi-01_* , 27 Jan 2025 |
