Shanghai Huaqian Bio-pharm intermediates co.,ltd mainly works in the development and research of special chemicals, cosmetics raw materials, and pharmaceutical intermediates. The company remember chemical basis function, and constantly improve the company system, varing from trade to research and development. We help our customers to get important information in various fields in order to help customers to better understand the quality of the products, functions, and application.
The company's main product 1,3-Dihydroxyacetone has stable process,fine quality and low price. The indexes of products meet the standard of the same products abroad. At present, we are the only manufacturer in China. In line with the concept of green chemistry, combined with various technical parameters and enterprise production of comprehensive ability, we combined the well-known domestic medicine enterprises designed and built with an annual capacity of 1000 tons of production unit. During that time, we study the quantitative, stability, security, toxicology toxicity of the product. All the indexes accord with a standard. As biomass bulk raw material, 1, 3-2 hydroxy acetone is widely used in foreign countries. At present the application in the domestic market is still in its early stages, but we believe it will create an important role in the China's green chemical business with its superior function.
1, 3 - Dihydroxyacetone
Polymer Cas number: the 62147-49-3 monomer CAS# : 96-26-4
M D L: MFCD00051019 EINECS no. : 202-494-5 FEMA registration number: 4033
Hs code: 38249097
Molecular formula: C6H12O6 molecular weight: 180.16
Another name: 2 hydroxy acetone, 1, 3-2 hydroxy dimethyl ketone
Feature: there are special odor. Taste sweet. Easily absorb moisture and decomposition. Its normal form is dimer.They Can slowly dissolve in a water or 15 of ethanol, slightly soluble in ether. Fresh products in solution can quickly turn into monomer, which easily soluble in water, ethanol, ether and acetone.
Melting point: 75 ~ 80℃
Quality standard: Appearance white to kind of white or light yellow powder
Infrared spectrum to identify Infrared spectrometry Conforms
Purity Purity was 98.0% (HPLC)
Water water or less 0.5% (K.F)
PH: 4-6
Water soluble: 250 g/L
Storage storage: seal 4℃ dry preservation
Use organic synthesis. Galactose oxidase of substrate. the artificial self-tanning agent
Our product process with glycerol as the substrate, using strain metabolic produce glycerol dehydrogenase in glycerin molecules of hydroxy for dehydrogenation, produce 1, 3-2 hydroxy acetone. Special separation technique was used to prepare high purity products. The technology of some methods have obtained national patent. At present, We has production capacity of annual output of 1000 tons. 1, 3-2 hydroxy acetone is mainly used in cosmetics self-tanning functional add , pharmaceutical intermediates heterocyclic compound synthesis, food nutrition supplements and feed additives, as well as the synthesis of polymer materials.
