Temperature Cross In Heat Exchangers
Posted 24 January 2013 - 01:14 AM
I would like to know, whether the temperature cross occurs in shell and tube heat exchanger is desirable or not? if it is how?
Thanks in advance.
Dnyandeo
Posted 24 January 2013 - 03:10 AM
This has been discussed in the past, find below links
http://www.cheresour...eat-exchangers/
http://www.cheresour...perature-cross/
Shivshankar
Edited by Shivshankar, 24 January 2013 - 03:11 AM.
Posted 24 January 2013 - 10:46 PM
I have seen those topics but it is not clear whether temp cross is desirable in shell and tube heat echanger? As per my understanding most are saying it is undesirable so avoid it.
But as per my understanding if I am getting outlet temp of cold fluid more than the hot fluid outlet.... why should i try to avoid it..if i am getting better heat transfer coefficient..
Thank You!!
Posted 26 January 2013 - 06:52 AM
I have seen those topics but it is not clear whether temp cross is desirable in shell and tube heat echanger? As per my understanding most are saying it is undesirable so avoid it. Yes it is undesirable..
But as per my understanding if I am getting outlet temp of cold fluid more than the hot fluid outlet.... why should i try to avoid it..because indicates a negative driving force for heat transfer between the hot and cold fluids...
if i am getting better heat transfer coefficient..It requires a large heat transfer area or high velocity to increase OHTC, otherwise to be avoided by, let say, using more exchanger shells in series...
Posted 27 January 2013 - 09:48 PM
You can't design a 1-2 heat exchanger with a temperature cross. But if the cross is not avoidable, then it is preferable to use 2 or more 1-2 heat exchangers in series. Moreover, the more shell you add, the less surface area you need (because the corrected mean temperature difference increases).
On the the other hand, temperature cross can and do occur during operation (after the HX is designed, built, procured and commissioned). I believe this is mainly due to excess surface. In this case the outlet temperature of the cold product can deviate and exceed the outlet temperature of the hot product. The result could be cold product degradation or exceeded design temperature on the cold side.
So I would say temperature cross is better avoided in both situations.
Edited by sheiko, 07 September 2013 - 12:07 PM.
Posted 01 August 2013 - 02:19 AM
I believe for true counter current flow, like 1-1 shell and tube HX. It is possible to get external temperture cross. But in some limitation.
Posted 01 August 2013 - 09:46 AM
Relieving TemperatureStarted by Guest_Falah_* , 01 Feb 2026 |
Best Heat Exchanger Type For Gas HeatingStarted by Guest_Gole_* , 29 Jan 2024 |
