Dear thorium90,
Thanks for your reply, but the paper attached with your last post depcits the H-x and H-y lines straight but they indeed are not completly straight as you can observe by the very formula using which the liquid and vapor enthalpies were calculated. Let's focus the attention to the liquid enthalpy first. The formula is as given below:
hx = xA * CpA * (T-T0) + (1-xA) * CpB * (T-T0) + del Hs
Neglecting the heat of solution, the enthalpy of the liquid (hx) depends on xA as well as T (the boiling point of the mixture). The T varies with xA as rightly done in the calculation that followed. So my question is that the H-x line can't be a pure straight line although it can be very close to the straight line as shown in the H-x-y diagram drawn in the calculation.
Whether I am correct or missing something. If I am correct then the very assumption of the Mc-Cabe Thiele method of constant molal overflow and constant molal vaporisation would be an approximation rather than a fact. But certainly I am not very sure. Also the very statement written by Treybal's (the attached diagram in the very first post) will not hold true.
Attached here is the chart drawn for the same values used in the calculation used in the paper. Also shown are the straight trend lines (in black).
Edited by Fardu, 11 February 2013 - 03:03 AM.
