Corroded Pipe Line Derating Pressure
Posted 17 February 2013 - 03:18 AM
Posted 17 February 2013 - 02:35 PM
Not being a specialist, thoughts as below could be only introductory. I remember a steam elbow of similar pressure (60 barg) was ejected some 60 m far in a local electricity station (1960s)(*). Consultation from a responsible (piping) engineer should be taken.
A1. Pipe is understood to be of Sch10 with wall thickness tolerance 12.5%. Thus minimum thickness of non corroded pipe s = 0.250×(1-0.125) = 0.22 in, mentioned. Corrosion depth (maximum) is understood as 0.22×45% = 0.10 in.
A2. Depth to wall thickness may be 0.22/0.1=2.2 (versus 2.05). This and "function of calculation" are not clear (to me), but may not affect what is written below.
A3. Referring to <http://www.cheresour...e-and-pressure/>, post no 4 (by kkala), presented example of thickness calculation would give wall thickness of 20×730/2/(20000+730×0.4) = 0.36 in, plus corrosion allowance, for the present pipe. Perry's table in Process Plant Piping does not present steels of allowable stress much higher than 20000 psi. I may miss something, but can you also check given pipe data? Is 0.22 in thickness adequate for 730 psig?
Β. At any case new design pressure could be estimated according to the applicable formula in B31 G, more or less similarly to the example of above mentioned post no 4. The new thickness is understood to be 0.22-0.10=0.12 in, corrosion allowance (say 0.04 in) has to be deducted from it and find what max pressure (at design temperature) corresponds to this thickness (say 0.08 in). Then a hydraulic test has to be made to certify the new design pressure.
Although above seems reasonable, an experienced piping engineer should verify (or even modify) it, who should also check loads not due to pressure (e.g. compressive loads due to thermal expansion).
(*) The steam line with the elbow was in the 2nd or 3rd floor, elbow was ejected out of the building.
Edited by kkala, 18 February 2013 - 02:58 AM.
Posted 18 February 2013 - 01:25 PM
Posted 18 February 2013 - 06:32 PM
Hi Toor, I had previously thought that new thickness is less than what required by 730 psig. Now I see "negative answer" means negative value resulting from an equation of B31 G. Does this negative value concerns pressure? But the latter would be a result of negative thickness, after the deduction of actual corrosion depth and corrosion allowance. This is hard to believe, probably something else is not clear (to me).
Using previous nomenclature and some simplifications, new thickness s = PD/(2SE) + CA (corrosion allowance), so P=2(s-CA)SE/D (B31 G will be somehow different), which means s<CA. Is it so?
Can you give more clarifications, step by step, along with your results? It may be useful to anybody intending to give a response.
Posted 26 February 2013 - 12:49 PM
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
Psv Downstream Line SizingStarted by Guest_Abdessamed1961_* , 03 Mar 2026 |
