I have a question about flash calculation. I got confused after performing the calculation and now I am still in the state of confusion. I have performed a very simple basic flash calculation.
So, I have the crude oil composition with me with some hypo components. The flash needs to be performed at standard conditions
T = 15.6C
P = 1 bar
Molar flow is 6848 kgmol/hour
So I have two streams now from the flash Separator:
Upper Stream - Vapor Stream
T = 15.6 C
P = 1 bar
molar flow = 5920 kgmol/hr
St. gas flow = 118.6 MMSCFD
St. Liquid Vol. flow = empty
Bottom Stream - Oil Stream
T = 15.6 C
P = 1 bar
Molar flow = 927 kgmol/hr
St. gas flow = 18.6 MMSCFD
St. Liquid Vol. flow = 31400 barrel/day
Now I wanted to mix both streams to get a one stream. Therefore, I have used mixer and added both Vapor and oil stream to get single output stream "dry crude stream"
Now, when I see the results in the properties under my Standard liquid volume flow, it says 100046 barrels/day which seems to be very wrong because in the begening I only had 31400 barrels/day.
Where is the rest of 68646 barrels/day coming from when my bottom oil stream shows only 31400 barrels/day?????
Thank you so much in advance
