Fluidized Bed Designing
Posted 21 February 2013 - 06:55 AM
Posted 21 February 2013 - 02:15 PM
There is a small section on fluidized bed reactors from page 1009 of Encyclopedia of Chemical Processing (Vol 2)
You could also read Chemical Reactor Design and Control by William Luyben
Best is to read from page 313, Chemical Process Design - Computer-Aided Case Studies by Alexandre C.Dimian and Costin Sorin Bildea
Edited by thorium90, 21 February 2013 - 02:21 PM.
Posted 21 February 2013 - 11:45 PM
You need to know a bit about the reaction kinetics to get the proper size reactor. The diameter is set based on fluid flow and fluid bed mechanics and the height is determined by the reaction kinetics. And there are cooling tubes within the bed, too.
Posted 22 February 2013 - 01:20 PM
Hey bobby, thanks for your input. I agree with whatever you said. It would be great if you could share some equations/references/steps involved in designing. I have actually done a lot of googling about fluidized bed reactor design and sizing, but couldn't find any.
Your help in this matter would be greatly appreciated.
Many thanks,
Raj Mehta
Posted 22 February 2013 - 01:36 PM
Hi, you will find those books in post 2 very useful. They show the equations/references/steps and are even specific to your problem: ammoxidation of propylene. It would appear you have not found and read those books yet.
![]() Help With Designing Shell And Tube DesignStarted by Guest_BabyKFC_* , 12 Jun 2024 |
Simulation Of Bubbling Fluidized Bed Reactor In ComsolStarted by Guest_Atronoush_* , 21 Jan 2024 |
Designing A Packed Distillation ColumnStarted by Guest_funkysticks_* , 18 Oct 2023 |
Designing The Internal Dimensions Of The Grease TrapStarted by Guest_rezagholipoor_* , 10 Dec 2022 |
Fire Case Psv DesigningStarted by Guest_tsaravanan1976_* , 24 Nov 2022 |
