Reformer Design Calculation
Posted 22 February 2013 - 09:53 AM
Posted 22 February 2013 - 10:05 AM
I assume you want to design a steam methane reformer? So what kind of furnace are you using? Side fired, top fired, convection type? The calculations would be similar to packed bed reactor but with heat flux at the tube walls. The number of tubes would depend on the plant production. More products mean more tubes needed. The appropriate steam carbon ratio to use would depend on the type of feed used and would determine the product composition. Low ratios cause coke formation and carbon laydown.
Edited by thorium90, 22 February 2013 - 10:14 AM.
Posted 22 February 2013 - 11:40 AM
Posted 22 February 2013 - 12:06 PM
Steam methane reforming is very widely used and there are lots of literature out there on it. Should be very easy to find. Xu and Froment's kinetics are widely used for modeling. Nielsen has many articles on the technology too. How do you intend to do the modelling? Software? Rigorous or more simplified modeling? You might find side fired is easier to model than top fired.
Edited by thorium90, 22 February 2013 - 12:07 PM.
Posted 22 February 2013 - 12:16 PM
Edited by rifat, 22 February 2013 - 12:17 PM.
Posted 22 February 2013 - 12:30 PM
Well, if you dont have to do any modelling, it would become alot simpler. Decide on a rate of heat flux, the production volume, airflow, fuel etc, a simple heat and mass balance will complete your project's calculation in under 1 day.
Edited by thorium90, 22 February 2013 - 12:30 PM.
Posted 22 February 2013 - 12:47 PM
Posted 06 December 2013 - 02:32 PM
hai i need the formula to design the mechanical design for primary reformer in ammonia and urea plant which consist of furnace design. could u guys help me what the calculation or the step to complete the design? myb some reference that i can refer?
![]() Scrubber DesignStarted by Guest_nasss_* , 07 Aug 2024 |
Smr Reformer Flue Gas FlowStarted by Guest_kaidlut_* , 14 Feb 2025 |
![]() Heat Exchanger Network DesignStarted by Guest_Kakashi-01_* , 21 Feb 2025 |
