How Is Composition Of Flue Gas Calculated
combustion biomass emission burning flue gas global warming simapro lca
#1 MusaP1
MusaP1
  • 5 posts
Posted 23 February 2013 - 01:50 PM
I mean to compare environmental impacts from using rubber wood chips,palm shell and wood pellets as the fuel for industrial boiler by Simapro program.
This program need to know the composition and quantity of emission to air like CO2,NO,CH4 in kg
but the information i have right now is C H N O composition of flue gas
For example, for palm shell
  Composition (kg) Carbon 721.1342937 Hydrogen 84.3885818 Nitrogen 151.920171 Oxygen 480.5569535
how can i use this data to find the composition (compound) and quantity of the flue gas?
i think i need to know the combustion equation
in my case,it is biomass so will it generate CH4 or NOx?
really thanks for helping and please tell if you want more information : )
#2 TS1979
TS1979
  • 164 posts
Posted 23 February 2013 - 02:41 PM
You can assume all the material to be completely combusted. In such case, if you know carbon, you can know how much CO2 to be produced
C+O2 =CO2
If you know hydrogen content, you can calculate how much water to be produced
H + O2 = H2O
Nitrogen is normally treated as inert gas and will not change in the combustion process.
The content of oxygen will be consumed for combustion.
The rest oxygen required for burn the wood materials will be taken from air (O2, N2).
Based on excess air (oxygen) requirement for the combustion, you can get your flue gas composition.
