1. How does one calculate the reaction forces on a rupture disc rupturing?
2. When a rupture disc is installed below a relief valve what is the magnitude of the reaction forces?
Rupture Discs
Started by Ram Prakash, Jul 29 2003 06:08 AM
Posted 29 July 2003 - 06:08 AM
Posted 30 July 2003 - 05:55 PM
I'm not a piping specialist so I'm not going to attempt to answer your question exactly. I will strongly suggest two references for you.
1. API RP521
2. "Guidlines for Pressure Relief and Effluent Handling Systems", Center for Chemical Process Safety, AIChE
There is a great deal of information in reference #2 on this topic including sample calculations. If you can find someway to buy the book, it comes with a CD with all sorts of relief calculations including reaction forces.
Incidently, if you are going to be involved with relief system calculations, this book is a MUST. It is well worth the $200 or so it cost (especially if you can get the company to buy it for you).
1. API RP521
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
Heat Exchanger Tube Rupture ConsiderationStarted by Guest_QuantumEng_* , 24 Oct 2023 |
Kettle Reboiler Tube Rupture CaseStarted by Guest_aniljani_* , 03 Aug 2018 |
Isolation Valve In A Rupture DiskStarted by Guest_Pronab_* , 28 Jul 2022 |
The Set Pressure Of Psv In Series Of Rupture DiscStarted by Guest_phoenixmoca_* , 15 Nov 2021 |
