Tomasso:
My comments on your previous post are as follows:
You should not attempt to dry the CO2 prior to compressing it to 250 psig. This is a foolish and wrong method that wastes a lot of money and energy without contributing anything to the ultimate water content of the CO2. Stop and examine what you are proposing – but as a chemical engineer using common sense. You know you have to compress the CO2 in order to ultimately liquefy it for storage. This, you must do. You also know, as an engineer, that as you compress the gas the water content the gas contains is less – especially because you have to cool the compressed gas after each compression. Therefore, by common sense, it is far more practical, cheaper, simpler, and effective to compress the gas through the designated 2 stages of compression, intercooling between each stage and separating the resulting liquid water in a vapor-liquid separator (“a trap”) and draining it. This removes the greatest amount of water (approximately 90%) without you doing nothing more than compressing and cooling the gas – which is exactly what you have to do anyway!
The above is the reason for selecting a proper, proven compressor type and arrangement before you do anything else. The compressor of choice for this type of operation is a reciprocating, 2-stage, no-lubricated machine with built in intercoolers and separators (with automatic drainers). The intercoolers are preferentially cooled with water because this is more efficient. After compression, you send the gas to the adsorption dryer unit where the last remains of the water content are removed. You can employ other types of compressors but you will have more problems and the process will be more complex. What I show in my workbook is what has evolved in the industry through many years of experiments and trials as the optimized method of producing liquefied CO2 for storage and transportation.
There is no sound or engineering reason to use a Water-Glycol system prior to sending the CO2 gas to a refrigeration system as I show in my flow diagrams. It makes no sense economically or practically to use a pre-cooler prior to the refrigeration system – unless there is something else that you are not telling us about or you simply want to buy excess equipment and make the process more complex and costlier to maintain and operate. But then, that is not engineering.
The conventional and correct method used to produce liquid CO2 is clearly shown in detail in my workbook. Please study it and ask any further questions you might have. It is quite simple and common sense. It is the way that CO2 is being produced today and the way it has always been done since I was born (76 years ago!).
Additionally, please be specific about what you mean by the term “cylinders”. Are these conventional, 25 kg capacity CO2 high pressure cylinders? Or are you talking about a cylindrical storage vessel? Please be clear and use diagrams, photos, sketches, or whatever else you need to clearly define what you intend to do. Conventional CO2 cylinders have a rather small (1”) valve and you simply can’t “pour” or drain Liquid CO2 into such an arrangement. You would have to literally pump the liquid CO2 at -8 oF into the cylinder and let it warm up to ambient temperature while the contents would rise in pressure up to 1,000 psig. The point here is that if that is what you intend to do, it isn’t practical to think that you can fill the cylinders without a special high pressure pump. Please be clear and give ALL THE SPECIFIC DETAILS.
