- We have a processing facility for the removal of condensate from raw gas and moisture contents. TEG based dehydration unit, three phase separators, storage of produced condensate and evaporation pond (90ft * 90ft) for produced water installed for the said purpose.
- The gas and liquid coming from all deep wells first pass through three phase separators to remove free liquid and condensate. Based on the retention time, the water coming with deep gas is first separated in three phase separators and then sent to portable water storage tank which then drained to evaporation pit while condensate separated in three phase separators sent to condensate storage tanks. Some portion of water settled down in condensate storage tanks as well, which is also drained from tanks to evaporation pond. At this stage some of condensate also drains along with water.
- Currently, the daily production of produced water and condensate is about 265& 90 BBL.
- We are also going to drill water disposal well.
- When an appreciable layer of condensate developed on surface of evaporation pond, we recovered the condensate manually and up-till now we have almost recovered about 1000bbl of condensate since 2011.
- We need a safe way to handle this amount of condensate by installing any physical means i.e API oil water separator or anything else, however, problem is that
- Condensate recovered from evaporation pit is
Sp. Gravity 0.8232
API. Gravity 38.57
Salts 1.1 PTB
While Condensate Collected in Storage Tanks
Sp. Gravity 0.820
API Gravity 41.06
- Condensate separated in three phase separator and storage tanks is seems to be emulsified and API oil water separator what i have conatacted to vedors their equipment only favorable for passing through non emulsfied oil.
PROBLEM:
1. Any way to improve the efficieny of three phase separator and that can handled emuslified oil for pure separation, in this case we can get the pure product in storage tanks
2. Crieteria or method for the selection of oil / Water separator that can fullfill our purpose (emulsified oil water) and we can diposeoff produced water free from oil
Edited by anjumaziz, 13 March 2013 - 05:37 AM.
