Scrubber Design For 35% Hcl Tank
#1 markcc
markcc
Posted 21 March 2013 - 08:41 PM
Dears:
           What concentration shall I taken for scrubber inlet?
           Below are my case:
           1. HCl tank: 20 m3. FRP
           2. HCl scrubber: 20 Nm3/hr for fume flow (maybe use 1 CMM for design), concentration: need help
           3. Type" vertical packed bed (water only)
           4. Recirculation pump capa.: 1 CMH
           5. Efficiency: 90%? based on inlet concentration to decide later!
           That all, please share u'r experience. Many thanks~
#2 wangyang
wangyang
  • 12 posts
Posted 21 March 2013 - 08:55 PM
The concentration of HCl could be estimated by the vapour pressure of HCl, and teh flowrate of waste gas should be considered following factors:
(1) the temperature change scope;
(2) The feed rate of HCl to this tank;
And the efficiency had relationship with the structure of scrubber, the operation parameter of this scrubber.
#3 sunil bendi
sunil bendi
  • 5 posts
Posted 26 July 2013 - 12:09 AM
Dears
I want to design Scrubber for HCL Tank .Two Tnaks OF 10 KL and 13 KL capapcity.
How to start.
Finally i should get what is height and dia of scrubber to be installed?
#4 breizh
  • 6,786 posts
Posted 26 July 2013 - 12:15 AM
Sunil ,
Use the search engine in this forum and you should get the support you need !
Key words : HCL scrubber design
