dear all;
i want to know what equipement can replace h2o filter (coalisser) in hysys and how it works .
thank you
Posted 09 April 2013 - 08:54 AM
dear all;
thank you
Posted 10 April 2013 - 12:26 AM
Hi lounis1
Separator in HYSYS can be use, if your intention is to removed free water (H2O) from the stream.
But if the filter is like a mol sieve or dessicant dryer, which removed saturate water. Best thing that you can do is to use a component splitter and to remove some of the saturate water and leave the water in the gas as what you required. Other than this you can try out by using a reaction column.
Separator in HYSYS works by, separating the gas and liquid stream (heavy and/or light liquid) and it does a perfect separation, which is means all the liquid are knock out from the gas and all the heavy liquid are separated from the light liquid. If you wanted to simulate something which is quite realistic, you can do some modification in the carry over set-up of the separator.
While the component splitter works by, removing certain species of component from the stream.
Edited by erwin.apriandi, 10 April 2013 - 12:31 AM.
Aspen Plus Rcstr Convergence Issue – Mass Balance Error In Anaerobic DStarted by Guest_Marie26_* , 05 Apr 2026 |
Energy Analysis In Aspen Plus 14.2Started by Guest_Sarishma_* , 23 Mar 2026 |
