Our existing facilities process heavy oil crude with 90% water cut becoming 1% BSW (BSW: base sediment water, the clean oil is transfered to Refinery), the process is very simple, is to separate oil from water.
The water is taken out via "water leg" from bottom of the tank, with a "water box" to control oil-water interface. The water is transfered with gravity flow to atmospheric pit.
The oil is spilled over to another tank with gravity flow, the outlet goes to bottom of secondary tank which has static head.
The problem occurs when we'd like to determine line capacity.
I have read some discussion about gravity flow design (article written by Hills). Key points from the thread, to have a self venting flow, the line should be sized so that the Froude Number (Fr < 0.3). This is to avoid vapor entrainment to liquid line which may bottleneck the flow.
But the problem is, if we follow the rules, in reality, our plant capacity may exceed the Fr = 0.3 without any significant vapor entrainment / flow bottleneck.
My question is : for my application, is it necessary to evaluate line capacity with self venting flow criteria? or for my process we may assume the pipe will always run full ?
