Dear all,
I have basic qurerry regarding how heat exchanger works...
Consider heat exchanger with cold fluid on one side ang hot fluid on other side.. heat transfer willl be from hot side to cold side due to their enthalpy difference...
My question is by keeping one side flow constant and varying other side what will be its effect on outlet temperature..
what i understood is if we change mass flow rate heat exchanger duty will change ( Q= M*Cp*dT)
Suppose i decrease hot side flow by keeping cold side flow constant .. it will result in decrease in heat duty of heat exchanger.. but i am sure that hot side outlet temperature will be less than previous one.. and also if i decrease cold side flow by keeping hot side flow constant cold side outlet temperature will be greater than previous one as there will more heat gain per kg ( though its heat duty will decrease)..
Now my question is how i can i prove this phenonmeno therotically... or please correct me if i have some misunderstanding reagarding this....
My collegues has different understanding over this they say that if i will decrease cold side flow by keeping hot side flow constant.. cold side outlet temperature can increase or decrease.... but according to me cold side temperature will increase...
Please help...
Satendra Deshmukh
Edited by satendra, 04 May 2013 - 06:52 AM.
