Co2 Removal Using Mea Simulation In Aspen Hysys 7.3
#1 majid_kam21
majid_kam21
Posted 06 May 2013 - 09:06 AM
hello every one
 I am trying to simulate the attached files pfd of co2 removal using MEA.
I have problems in both stripper and absorber.I have used both rate based column(aspen) and distillation column and I have tried amine pkg and also ELECNRTL the reactions of MEA are also involved yet I cant simulate it correctly.is there anyone who can fix it?I have attached the pfd and a picture of the aspen hysys file if anyone wants the file I can mail it to him/her
in the attached file I have used a rate based column as an absorber the co2 is removed from the feed but the removal too much that there is actually no CO2 in products.
I was forced to use the distillation column because I couldnt use rate based column(molar flow of CO2 @ vapour outlet of the condenser was zero).but I had some other problems too.the CO2 absorbed was reacted with MEA so I couldnt use a distillation column as a stripper.so I was forced to put an adiabatic conversion reactor in order to reverse the reaction to MEA and CO2.the conversion reactor in this file is used for the mentioned problem(although I am almost sure it is not right to use it.)
if you do not have this version tell me what sort of informations do you want so I can give it to you.
thanks a lot
majid kamyab
student of chemical engineering
tehran university
Edited by majid_kam21, 06 May 2013 - 01:20 PM.
#2 thorium90
thorium90
  • 1,073 posts
Posted 10 May 2013 - 07:33 PM
Hysys already has an example file on CO2 removal using MEA in its folders. Comes with the installation of hysys..
