Q Line Equation
distilation column design
#1 mubarak56
mubarak56
  • 21 posts
Posted 09 May 2013 - 02:18 AM
how can i find value of q for calculation of number of stages in design of distillation column????
i have two components both have different values of heat of vaporization and different values of Hfs and Hf but in determining value of q only single values are used so how can i find values of q.
#2 thorium90
thorium90
  • 1,073 posts
Posted 10 May 2013 - 07:37 PM
Q value as in the quality?
#3 Art Montemayor
Posted 11 May 2013 - 09:25 AM
I believe the topic is supposed to be the "q" line as defined by the McCabe-Thiele method for calculating the number of distillation stages in a given separation.
The condition of the feed as it enters the column has an effect on the number of trays, reflux requirements, and heat duties for a given separation.  The thermal condition of the feed stream entering the column is designated as "q" and is approximately the amount of heat required to vaporize one mol of feed at the feed tray conditions, divided by the latent heat of vaporization of the feed.
I would ask the OP: Is the above the correct topic you want to discuss?
#4 mubarak56
mubarak56
  • 21 posts
Posted 13 May 2013 - 10:38 AM
yes q for quality....
and above is the topic that i want to disscuss
i hope you have understood my question
i am asking talking abut the calculation of q line equation required in designing distilation column
