that depends from mixture composition (i.e. condensate composition) and the list of models available in your software application,
for sizing / rating pipelines I have utilized Excel with Prode Properties as process simulation library,
with Prode you can select specific models as CPA, GERG, SAFT, Peng Robinson or Soave Redlich Kwong with complex mixing rules (Wong Sandler, or Huron Vidal) etc.
Selecting a model is not easy as every model has its limits which you should consider, but, in general, they can be more accurate than std. EOS with VDW mixing rules. (i.e. the PR or SRK packages available in most software applications).
