hi all
please could any one help me !!
how to enter water content data in hysys (if not included in composition)
if given by ppm ?
please help
best regards
elgenedy
Posted 20 May 2013 - 03:01 AM
hi all
if given by ppm ?
please help
best regards
elgenedy
Posted 20 May 2013 - 04:20 AM
given by ppm? you just convert it to mass fraction then input it.
Posted 20 May 2013 - 04:48 AM
no problem with conversion
i'm just asking if the gas composition was given 100% without water
and water was given by ppm
Edited by elgenedy, 20 May 2013 - 04:49 AM.
Posted 20 May 2013 - 05:18 AM
elegenedy,
You have not clarified whether you are mentioning a liquid stream or gas stream without water. You need to clarify this first.
Assuming that you are describing a gas stream on a dry basis (without water) then you need to configure two streams in HYSYS. Stream 1 will be gas stream on dry basis and Stream 2 will be water. The two streams will then enter a mixer block in HYSYS. The outlet stream of the mixer block (Stream 3) will be your gas stream on wet basis (with water).
Posted 20 May 2013 - 05:52 AM
Ankur
i'm already describing a gas stream
assuming that the gas stream in dry conditions is 4.5 MMSCFD @ 195 psi, & 88 oF
Components - Mol %
Nitrogen - 0.421
Methane - 49.330
Carbon Dioxide - 7.638
Ethane - 14.554
Propane - 17.225
i-Butane - 3.165
n-Butane - 4.787
i-pentane - 1.142
n-Pentane - 0.937
Hexane - 0.530
Benzene - 0.010
Heptane - 0.154
Toluene - 0.016
Octane - 0.060
Ethyl-benzene - 0.002
p.m-xylene - 0.005
o-xylene - 0.003
Nonane - 0.016
Decane plus - 0.005
Total - 100.000
Mol Wt = 30.228
Sp Gr (Air =1.0000) = 1.0437
Eq. Liquid Density = 0.4105 g/ml
water content was 10,792 ppm @ 30 psi, 54.5 f
please describe how could i simulate this in hysys
thanks for your help .
regards,
elgenedy
Posted 20 May 2013 - 06:00 AM
10792 ppm is 1.0792%
Add that to your 100%
Total
100.000
You will get 101.0792%
Normalize everything to 100%
These will be the new percentages you input into hysys.
As you might have observed, I'm totally disregarding the temperature and pressure given by you since your values , units and its degree of accuracy seem to imply you are reading these values from some GC analyzer? If so, then it doesnt matter what temperature and pressure you are reporting anyway.
If not, you can just make 2 streams with those specs at those temperature and pressure then use the MIX unit module. Simplest method.
Edited by thorium90, 20 May 2013 - 06:13 AM.
How To Estimate The Water Dewpoint From Heat And Mass Balance Of NaturStarted by Guest_krishnnaa26_* , 30 Apr 2026 |
Importing Component Stream Data From Hysys To Excel Using VbaStarted by Guest_TimL_* , 17 Aug 2018 |
How To Handle Water Byproduct And Man Hydrolysis In The Dbp Solvent RoStarted by Guest_martzian_* , 20 May 2026 |
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
