Good afternoon all,
I would like to know if there is any critical impact on the results of the bore if I were to use a program such as InstruCalc or Flow Consultant to size for an RO as these programs only allow calculations for assemblies with flange tappings.
Thank you very much in advance.
Nicholas
Restriction And Square Edged Orifice Sizing
Posted 03 June 2013 - 03:01 AM
Posted 03 June 2013 - 05:07 AM
Nicholas,
You may consider Perry's chemical engineer's handbook to support your query .
I 've added an excel sheet ,Base is Crane Flow of Fluid, it might helps you .
An other resource to consider too:
http://www.pipeflowc...ns.com/orifice/
Edited by breizh, 07 June 2013 - 01:03 AM.
Posted 03 June 2013 - 07:20 AM
Nicholas,
You can use this programme.
We are also using this programme for the orfice sizing.
Jatin
Posted 03 June 2013 - 09:25 AM
If you search the site for your subject, you should find a link to download a program for such.
Posted 03 June 2013 - 08:13 PM
Thank you all very much for your assistance.
Batch Adsorption: H/d Ratio For Vessel SizingStarted by Guest_Victor_process_Engineer_* , 28 Feb 2025 |
![]() Separator Sizing Step By Step ProcedureStarted by Guest_krishnamurthy_* , 06 Apr 2023 |
