Hi everybody,
I am a process design engineer in the refining field at the basic engineering step (licensor).
During unit designs, I often specify heat exchanger process datasheets. Those exchangers will be sized rigorously by detailed engineering at a later step of the project.
To establish the process datasheet, I simulate the unit using Pro II and the process/process exchangers are considered either 1 pass shell/2 pass tube (TEMA shell and tube HX, considering an Ft < 1) or 1 pass shell/1pass tube (double pipe HX, considering an Ft = 1 for perfect counter current flow) depending on the size of the exchanger.
To determine the sizing case of the exchanger, I first simulate all the cases with a fixed Hot Outlet temperature minus Cold Outlet temperature (T2 – t1). Then I identify the maximum UA case, and I apply this UA to all the cases. Doing this assumes that the heat transfer coefficient is constant for all the cases - which is not the case in the real life since it depends a lot on the throughput to the exchanger (U = f(Re)). Please refer to the attached sketch.
As a result, for the sizing case, the resultant HOCO (T2 – t1) is equal to the HOCO I have simulated first, while all the other cases - and especially the turndown case (50% capacity) - the HOCO is less.
If, for the first simulation, I take the HOCO = 0 °C, then for the other cases, the resultant HOCO is negative. For the turndown case in particular, the resultant HOCO in the simulation could sometimes be as low as -50 °C to satisfy the equation Q = Ft*UA*DTM.
It is nonsense to consider such a low HOCO since in the real life, a temperature cross must be limited to a much higher HOCO than -50 °C. The wrong assumption in this method must be that UA is considered constant. For this reason, I have considered until now that the HOCO cannot go lower than -5 °C.
I do not have access to HTRI and I do not have much feedback from the field. Does anybody have experience in this lower throughput case in the field? What is the lowest HOCO that can be seen on site? Is this value of -5 °C acceptable?
Thanks for your answers.
Edited by Art Montemayor, 10 June 2013 - 06:04 PM.
Composition
