Dear All-
I am struggling with saturating a stream in HYSYS using ADJUST. I have a predefined (temp, press, composition known) dry gas stream. Defined a water stream at same temperature and pressure and picked a flow say 100 lbs/hr. Put it in a mixer and downstream a 3 phase separator.
Now I want to use Adjust so that HYSYS tells me how much water do I need to saturate this gas stream at conditions downstream of the mixer. A crude way would be to keep changing the water flow, unless and until you start see some dropout free water.
But how do you use ADJUST in this case. Please see the attached simulation, wher I have specified the taget value of the dropout as 30 lbs/hr, while i still just see 9.61 lbs/hr of water.
What am i doing wrong?
comments will be greatly appreciated..
