Cv For 2 Phase Flow - Fisher Cv Correction Factor (Fm)
blow by breakthrough blowby blow-by control valve sizing
#1 Christiano
Christiano
  • 21 posts
Posted 16 June 2013 - 12:53 AM
I find the calculated CV requirement for a typical 2-phase flow of gas and liquid (when gas volume ratio is near to 90%), the calculated CV differs about 100 % between Masoneilan and Fisher methods...Any suggestions on your experience with Fisher Fm correction factor charts which makes it larger??
#2 mansari
mansari
  • Store Customers
  • 46 posts
Posted 16 June 2013 - 04:11 AM
Control Valve sizing employing Two phase flow is tricky and Cv calculations requires good engineering judgement. Other than Fisher and Masoneilan, I hope the attached documenrt (page 3-15) would be useful for your calculations
#3 mansari
mansari
  • Store Customers
  • 46 posts
Posted 16 June 2013 - 04:13 AM
Here is the file
#4 Tom Berenger
Tom Berenger
  • 10 posts
Posted 23 June 2013 - 11:11 PM
I will advise you to use the ISA equations, rather than Fisher. I find ISA a lot easier and all the factors and coefficients are listed for each scenarios. I have the full manual if you want me to send it to you.
You can also download the valve sizing software on Fisher website. What I usually do is use the ISA  equations for my hand calculations and then compare with the results from Fisher software.
