hi all,
Anybody can help me out regarding the following topics. I just need basics about the following topics.
-- Line Sizing
-- Hydraulic Calculation
-- PSV load calculation
thanks a lot.
suresh reddy.
Line Sizing, Hydraulic Calculation, Psv Load Calculation
Started by suresh2, Feb 23 2006 11:04 AM
Posted 23 February 2006 - 11:04 AM
Posted 13 March 2006 - 11:12 AM
This is a very general question. I propose you search the forums here and at eng-tips.com, and google for it. There are a lot of resources on the web.
Any book on Chemical Engineering will also give you more info than you can swallow ;-)
Posted 22 March 2006 - 02:26 AM
Hi suresh...
Posted 27 May 2006 - 07:59 AM
Hi suresh reddy,
Line sizing is basically done from "Darcy equation". For application of this equation, you can refer to Ludwig, vol-1. Various cases are mentioned in this book. Like Liquids, compressible gases etc.
Hydraulic calculation means making a pressure balance in the process flow based on the preliminary P&ID. The inputs are pipeline pressure drop, equipment pressure drop. Normally pipeline pressure drop contributes around less than 20 % in a typical process flow. You take up a PFD and P&ID do it yourself once, you can learn easily.
PSV load calculation is based on "Transient analyisis" of all relief valves in a process plant and grouping the PSVS of probable failures. This is a detailed calculation procedure. If you take up a Process P&ID and start grouping the PSVs for various failure cases like Blocked outlet, cooling water failure, fire etc, you can logically derive the quantities of the PSV loads.
I think you are asking about these topics while looking for a job oppurtunity in Detailed Engg Contractor companies. Above are the minimum skills a process engineer should have to get a job in DEC.
GK Kannan.
GK Kannan.
Surface Area Calculation For Blowdown Orifice Sizing Including FinnedStarted by Guest_victortheone_* , 17 Feb 2026 |
Steam Drum SizingStarted by Guest_nastaran_* , 01 Dec 2025 |
Equal Load Sharing And Anti-Surge ControlStarted by Guest_panoska_* , 02 Nov 2025 |
Sizing Of Condensate Return VesselsStarted by Guest_panoska_* , 23 Oct 2025 |
Horizontal Decanter Sizing CalculationStarted by Guest_peejoee_* , 07 Oct 2025 |
