Hi there,
I was wondering how the length and opening size of an half-open pipe in a knock-out drum shall be determined. The relating Shell DEP and API 12J don't give an answer to that. Criteria are described to comply with maximum momentum of the inlet nozzles (rho x v^2 shall be less than xxx Pascal), but the actual size of the opening in the pipe and the length are not described.
Is it that simple as the open area of the pipe shall be at least or larger then the area of the nozzle? That's almost in all instances the case. I assume "half-open" refers to the half of the diameter, but it's doesn't say anything about the total open area.
Kind Regards,
Enrico Lammers
Edited by Enrico Lammers, 21 June 2013 - 02:49 AM.
