Good morning,
This post is in response to the thread “Storage Tank Heat Loss Calculation Based on Kumana and Kothari Article.” As the storage tank forum is closed to posts I’m going to ask the question here.
http://www.cheresour...othari-article/
http://www.cheresour...ss-calculators/
I found both the paper and spreadsheet very informative and detailed, but I have one question on the spreadsheet which is in regards to the end of the spreadsheet where the time is found to drop the tank temperature.
I understand that you need to solve the differential equation Utot x Atot x ΔT = m x Cp x dΔT/dt, solving for time. However, I’m having a difficult time trying to understand how you can add up the total overall heat transfer co-efficients (i.e. Udry wall, Uwet wall, Uroof, Ubottom) and multiply them by the sum of the different areas (i.e. Adry wall, Awet wall, Aroof, Abottom) as done so in the spreadsheet. Please note, from the spreadsheet, the overall heat transfer co-efficients and areas for each component of the vessel have already been determined. See cell C416 for the calculations.
If anyone could please clear this up and/or provide a better understanding of the matter, it would be much appreciated.
SAprocessGD
