I am facing problem to calculate accurate pressure drop for transition flow region. Fluid is fuel oil with viscosity of 680cp and density 999kg/m3. Based on NRe, flow is in transition region. Using Colebrook equation (which is truly applicable to turbulent region) for friction factor calculations, results of different programs vary significantly. Can some one help to guide how to counter this situation?
Is there other equation to calculate friction factor in transition region?
Can we rely on Colebrook equation results? If yes then shall we rely on programs like Pipesim, Stoner or in-house spread sheets? It is noted that calculated friction losses from in-house spread sheet are lot more as compared to simulation program results.
Please share your thoughts.
