I am currenly working on a gas plant consisiting of Compressor, AGRU and TEG dehydrtaion units. I have to decide the Design pressures & temperatures of various equipments. While the Compressors and downstream Gas treatment sections like Amine column and TEG column will be designed for compressor shut-in, I am facing a bit of delimma deciding the design temperature and pressures for the Amine Regenration column and TEG reboiler.
Both the systems operating at relatively low pressures 4.5 bar a for Amine Regeneration & below 2 bar a for TEG reboiler.
The heat source for Amine regeneration is LP steam, where as that for TEG reboiler is HP steam.
For Amine regenerator column, I have calculated a design pressure of 5.2 barg (applying margins as per BOD)and temperature of 160 deg C designed for LP steam
similarly, For TEG reboiler I have calculated a design pressure of 3.5 barg and 293 deg C for HP steam.
Friends, do I need to consider any other condition for reaching the deisgn pressure & temperatures. especially for TEG reboiler do I need to consider tube rupture which will bring the design pressure of reboiler to 10/13 of 46 = 35.4 barg?
thanks and regards,
B-2 Spirit.
