Jacketed Piping is commonly used to convey very viscous process fluids in an inner pipe, heated by steam/hot water/hot oil or other heating medium between the jacket and core pipe. Vacuum jacketing is also used as an insulator for cryogenic fluids and can be analyzed using the same calculation method for heated jacketed piping. For more read http://processpiping...ted-Piping.html
No replies to this topic
Posted 08 August 2013 - 06:52 AM
![]() Guidance On Sizing Jacketed Pipe For Glycerine CoolingStarted by Guest_Kentucky08_* , 28 Jun 2025 |
![]() What Kind Of Cooling System Should I Use To Cool Down A Jacketed MixinStarted by Guest_HollyBoni_* , 31 Jan 2025 |
Maximum Velocity For Piping In Fire Water Distribution System (Fire WaStarted by Guest_applepe_* , 06 Sep 2024 |
![]() Heat Transfer In Jacketed EvaporatorStarted by Guest_haseeb00718_* , 19 Aug 2024 |
Pressure Drop In PipingStarted by Guest_Jaldhipatel_* , 05 Jun 2022 |
