Dear all,
I have following queries related to liquid ring vacuum pump.
We are using LRVP to maintain vacuum in our plant.we are planning to install VFD due to low load on pump.However in vacuum pump minimum impeller tip speed is to be maintained to keep liquid ring intact in pump.My question is how to calculate it.following data might be useful.
actual vapor load: 11 nm3/hr ( calculated by leakage rate calculation)
Designed load : 88 nm3/hr
motor amp.: 37 (actual reading of meter)
Rated kw : 30 kw
pump RPM : 985
I would also like to know that installing VFD will serve the purpose of power saving.
Minimum Impeller Tip Speed
Started by himanshujdalal0713, Aug 14 2013 07:47 AM
Posted 14 August 2013 - 07:47 AM
Posted 15 August 2013 - 12:05 AM
Consider reading these papers .
Hope this helps
Edited by breizh, 15 August 2013 - 12:15 AM.
Posted 15 August 2013 - 01:53 AM
Dear breizh,
Thanks for the references provided by you. Second reference suggest testing method for checking minimum impeller speed however it will be of great help if any theoretical calculation is available as it will not disturb running plant.
Short Path Distillation Rotor SpeedStarted by Guest_MEC_* , 11 May 2023 |
Minimum Vapor Disengagement Area For A Kettle BoilerStarted by Guest_Engib33r_* , 17 Oct 2024 |
Carburization Speed Of Steam Cracker Radiant CoilsStarted by Guest_Movers_* , 26 Jun 2020 |
Minimum Tower DiameterStarted by Guest_AnbIran_* , 17 Nov 2023 |
Variable Speed Pump CurvesStarted by Guest_panoska_* , 27 Jan 2024 |
