Generally hydrocarbon pressure vessel LG/LT drains are connected to closed drain system. In a running plant, normal operating procedure for taking these instruments in maintenance, shall be as follows:
- Isolate the instrument.
- Depressurise to flare system.
- drain to closed drain vessel.
In case, there is a difference in rating & design pressure of system, I have seen a practice of providing flow restriction orifice in these drain lines. Reason given is to safeguard the drain system against a possible gas blow by, from the pressere vessel through instrument line.
My underatnding w.r.t. these ROs is limited, & I have few queries:
- I have worked for @ 4 years in operations in refinery & petrochemical complex in India, but I don't remember seeing these ROs. Also in my similar process design experience I have never come across these. I may have missed the same due to limited exposure. Now I want your opinion on the same that - Is it a good rather acceptable & common practice to do so?
- I understand that the requirement of these ROs is to restrict the flow rate so that you don't need to size the drain system relief for the purpose in case this becomes the governing case. If yes what shall be the criteria for sizingsuch ROs?
- Also I guess choked flow scenerio shall be envisaged as generally we encounter pretty small valve sizes in instrument drain system & we do have critical pressure scenerio. Now in case the choke flow equatin gives a smaller amount shall we specify the same flow for orifice also if this value comes pretty high & clealy surpasses the amount for which drain relief is designed, what shall be specified for RO.
I request veteran members to provide their views on the same. seniors can also guide me, if this is not the right place to post such query.
Edited by Sharma Varun, 16 August 2013 - 02:17 AM.
