On an exchanger drawing I inherited, it is spelled out that tube to tube sheet joint is strength weld, tube hole grooving not allowed, and expanding of tubes in tube sheet not allowed.
For this service, leak from one side to another side should be prevented. I thought the joint type of strength weld with grooving and with expansion is the best you can get , and surely better than strength weld without grooving and without expansion (sorry for the lengthy sentence, I just try not to add confusion). Are grooving + expansion not compatible or not allowed by certain codes when strength weld is specified? Or is this specification just a personal preference from the previous designer?
Really appreciate comments from experts from our community.
