Hi everyone,
We have an interesting scenario on site (we're busy commissioning). We have a flare stack that must be able to handle a flow of between 400Nm3 (Min Design) and 10000Nm3 (Max Design for which the flare will still burn). Usual operation should be around 400Nm3 (Operating Point), however, this could experience very rapid (step) changes of around 2000Nm3.
At a flow rate of 5000Nm3 the water seal is blown completely out of the flare. The flame is not put out, but neither is the water completely evaporated. Quite a bit of water ends up running down the side of the flare stack and showering the surrounding area. The water travelling up the inside of the flare doesn't seem to do the dust monitor and equipment in the nitrogen purge line any good either.
According to the flare vendor this is quite normal (??). The idea, it seems, is that at high flows, the water seal will be constantly topped up (and blown out the top of the flare) so that in the event of the flow decreasing, the water seal will remain intact. This is important since the primary function of the water seal is as a flame arrestor (which of course is only relevant at low flows).
The problem is that we cannot afford to waste that amount of water out the top of the flare. The plant will not be in constant operation and so at each start-up the water seal will be lost during the initial high flows.
So, my question is this: is it actually normal for a flare seal to be blown out? What can we do to prevent this happening? If there really isn't much that can be done, any suggestions on a control philosophy for keeping the liquid seal intact without blowing the water into the atmosphere?
BTW I haven't looked at API 521 yet. There is a height of around 1m above the water level before the stack narrows. If there is a thread that deals with this topic, please do direct me to it - I couldn't find anything when I searched.
Best regards,
William
