Dear All ,
I am planning to fill a vessel with 30atm 147 C air available using a 1/2" pipe 500 m long . I wish to calculate the flow through the pipe .( with vessel at atmospheric condition initially) .
p1 = 30 atm
p2=1 atm
L=500 m
Sg=1
T=147+273=420k
d=15.8 mm
I have used Waymouth Equation to find the flow & has got a result of 125 NM3/Hr. Is it correct ? I am little doubtful as this does not take into account the exit , entracnce & valve etc. resistance coefficients.
I have tried to calculate the same using Darcy's equation for compressible fluids . If I calculate K
K=f*L/D
K=0.027*500/0.0158
K=854
If I add other resistance cofficients , It may become near to 860 ,But the problem here I encounter is that I cannot use Net Expansion factor & Limiting factors for sonic velocities curves as these are avaialble for K upto 100 only.
Please help .
