How do you find the latitude of a tank? I am trying to calculate the thermal outbreaking for tank vent sizing and I need to find the Latitude of the tank so that I can get the Gamma factor according to API 2000...There are 3 laititudes listed: Below 42, Between 42 and 38 and Above 58 degrees. I need to know where to find the latitude factor of the tank....
Thermal Outbreathing Calculation Latitude Of Tank
Posted 05 October 2013 - 08:40 PM
Posted 05 October 2013 - 11:03 PM
Remember latitude/longitude you learnt in Geography class. Latitude is not of tank, but of the location where tank is placed. Which country/city is tank located in. Just google for latitude of that place.
Latitude affects solar insolation received by that place and hence tank outbreathing.
Sachin
Posted 05 October 2013 - 11:07 PM
uwaterloo,
Refer the link below if we are talking about Waterloo, Canada:
https://www.google.c...us:IE-SearchBox
http://www.travelmat...aterloo, Canada
Posted 05 October 2013 - 11:12 PM
In my opinion, lattitude of the plant site should be considered which can be taken from Google Search.
Posted 14 October 2013 - 01:28 AM
Thank you all.
Posted 14 October 2013 - 06:53 AM
One other comment on this thread, I have found the EPA Tanks 4.0 program quite useful for this purpose in the past, and it's free. It generates reports, and has physical data for common compounds.
Posted 14 October 2013 - 09:21 AM
A comprehensive excel workbook for normal venting (inbreathing / outbreathing) calculations based on API 2000, 6th edition, 2009 is available at:
http://webwormcpt.bl...estimation.html
Ankur
Surface Area Calculation For Blowdown Orifice Sizing Including FinnedStarted by Guest_victortheone_* , 17 Feb 2026 |
Thermal Oxidizer HeaderStarted by Guest_ryn376_* , 29 Jan 2026 |
10.000 M3 Tank Cost EstimationStarted by Guest_stelu85_* , 01 Jan 2026 |
Thermal Relief Valve For A Fire CaseStarted by Guest_QuantumEng_* , 19 Nov 2025 |
