Hi all,
I need your help once again please.
We have a Nitric Acid [40% nitric acid] pickle tank at about 85 deg C and another pickle tank containing a mixture of hydrofluoric acid and nitric acid [2% hydrofluoric and 30% nitric acid] at about 30 to 35 deg C. Please note that vents from both tanks are connected to a common ducting header.
I wish to select the material of construction for the ducting with approx diameter of 700mm and not sure which one is most suitable material of construction for above chemicals.
I am aware that hydrofluoric acid attacks glass and therefore, GRP is a non-starter. PVC and PVDF not suitable for higher temperature?
I believe PTFE would be suitable [PS: I am aware of cost issue ] but wondering if someone has past experience and PTFE gives of chlorine at such high temperature.
Thanks in advance for your help.
KS
