...Can u explain to me following:
As I know centrifugal pumps are mostly driven by fixed speed electrical motors,does it mean that speed can't be changed at all,or we can change it later on if necessary to increase flow,and how it's done ?
Volumetric piston pumps - flow depends on piston stroke (that can be chaged on pump itself)...and on piston speed,my question is how it's done, how do we change piston speed ?
And how do measure performance curve for volumetric piston pumps with say gauge glass (gg) ? ...do we conect suction to that gg with some flexible pipe? What about diccharge?
Thx for replies !
Pumps
Started by Guest_Guest_tom_*_*, Mar 14 2006 02:47 PM
Guest_Guest_tom_*_*
Posted 14 March 2006 - 02:47 PM
Posted 15 March 2006 - 01:01 PM
Tom:
By your questions I can tell you’re not familiar with pumps nor have you had hands-on familiarity with them. That’s OK. We all have had to go through the learning process. The real important thing I want to leave you with is that you should not feel constrained or any less an engineer simply because you haven’t had the exposure to pumps that you need. The opportunity will come in due time and you’ll see then how really simple and common sense they are and how they operate. Now for your questions:
!) The speed at which a centrifugal pump is driven is changed with ease – in fact, VSDs (Variable Speed Drives) are becoming common place as drivers on these pumps in order to control their delivery capacity and save on energy at the same time. In the old days – when steam power was “King” – it was common place to have most centrifugal pumps driven by steam turbines – and the speed could be varied at will. Of course, you must realize that when you change the speed of a centrifugal pump you are also changing the head characteristics as well as the capacity. This is an aspect peculiar to a centrifugal device and not to a positive displacement type of pump such as a piston type. You can vary the speed of an electric motor drive in several ways; through a multi-pole motor or a VSD.
2) You also change the speed of a positive displacement pump in the same manner. In the specific case of a piston type of pump, you also have the option to apply a “Reeves” drive – which is a variable pitch belt drive that attaches itself between a constant-speed induction electric motor and the pump coupling.
3) There actually is no need for a so-called “performance curve” for a piston type of positive displacement pump. The displacement is directly proportional to the speed or to the stroke, so all you do is create a spread sheet relating the capacity at the different settings. All this assumes that your valves are seating properly and sealing 100%. There is always some slippage (or leakage) through the valves, but you can document empirical losses on an actual application and apply this field data to the operation.
Normally, the displacement of positive displacement pumps is varied in step changes – not differentially (as in a VSD).
I hope the above answered all your questions and concerns.
![]() Centrifugal PumpsStarted by Guest_panoska_* , 01 Feb 2025 |
![]() Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
Vibration Of The Pump (Reciprocating Pumps / Plunger Pumps)Started by Guest_vsedhuraman_* , 06 Oct 2023 |
Variable Speed Pumps Operation.Started by Guest_panoska_* , 11 Oct 2022 |
Advantages Of Diff Types Of PumpsStarted by Guest_CHEMSTRONG_* , 09 Aug 2022 |
