I'd like to know if SS316L is suitable for use for a distillation column bottom given following conditions:
Inlet Flow (tower middle) - 712 Kg/hr at
* Temperature - 85 degC ,
* Process Stream Composition - water 56%, Methanol 19.9%, Glycerol 21.8%, NaCl 1.2%, Fatty Matter 1.1%.
Outlet flow (tower bottom) - 594.93 Kg/hr at
* Temperature - 105 degC.
* Process Stream composition - water 69.9%, Methanol 0.1%, Glycerol 27.2%, NaCl 1.5%, Fatty Matter 1.3%.
Ph of inlet and bottom outlet streams is 6-7.
Possible Corrosive matter : Chlorides and fatty matter( fatty acids)
Thanks in advance.
Selection Of Moc For Tower Bottom
Started by onyxgaze, Mar 15 2006 05:20 AM
Pump Selection ProblemsStarted by Guest_kito-818_* , 14 Nov 2025 |
Compressor Selection Based On Flowrate & Compression RatioStarted by Guest_Dhams_* , 19 Jan 2026 |
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
Distillation Column Top & Bottom TemperaturesStarted by Guest_halkeshhulk_* , 09 Jun 2025 |
