Minimum Seal On Lco Draw Off Line To Lco Stripper
#1 Eric Nguyen
Eric Nguyen
  • 42 posts
Posted 30 November 2013 - 09:41 PM
Dear All
I read PID and find out the  Note1: Provide minimum seal 1m. What does this mean?Why we need minimum seal here.
I attactched PID which related to My question.
Could any one in forum explain to me? The question look basic to designer..!
Thanks you
#2 SSWBoy
SSWBoy
  • 58 posts
Posted 06 December 2013 - 02:44 PM
This line is free draining from T-1501, how does the elevation of the nozzle on that column compare with the nozzle on the LCO stripper?
#3 AnandS
AnandS
  • 5 posts
Posted 07 December 2013 - 02:54 AM
Hoang,
Basically it seem that, designer do not want to consider the two phase flashing at outlet of control valve & also want to flashing will take place only inside the stripper. Normally liquid seal provide inlet or outlet to avoid the two phase flow to control valve as two phase inlet control valve design is very difficult.
I have no PFD or HMB but you can check by yourself.
