Designing A Flare System
flare design
#1 KeJoSa2010
KeJoSa2010
  • 41 posts
Posted 07 December 2013 - 08:29 AM
In the past I have been involved in projects in which I was helping to rate existing flare headers, size PSV's and such but, I have never been involved in designing a non-existing flare system. I am familiar with API 520/521 but, I am hoping someone can point me to some literature that will give me a better understanding of the overall design process (not the process of rating existing equipment but, the design procedure for a non-existing flare sytem). For example, how does one determine where the flare stack is located on the lease? How does one determine the required height of the stack? I am sure a dispersion model is used somehow but, how? As for sizing of the header and stack itself I am sure a program like Aspen Flare Analyzer (Flarenet) is useful.
I would like to outline the main process considerations that go into designing a flare system from scratch.
Thanks!
Edited by KeJoSa2010, 07 December 2013 - 08:32 AM.
#2 AlertO
AlertO
  • 194 posts
Posted 08 December 2013 - 11:11 PM
Dear KeJoSa2010
i think you can find the answer of your questions in API 521 describing the design of each element in the flare system. Just look through it again.
#3 breizh
  • 6,805 posts
Posted 09 December 2013 - 01:41 AM
Hi KeJoSa
Hope this is helping you .
Edited by breizh, 09 December 2013 - 01:53 AM.
#4 fallah
  • 5,019 posts
Posted 09 December 2013 - 02:06 AM
It might reading API 537 titled; "Flare Details for General Refinery and Petrochemical Service" be a good starting point...
#5 jrtailor09
jrtailor09
  • 158 posts
Posted 09 December 2013 - 07:33 AM
Please go through the API 521.
There are two method for the Flare stack height finalization.
1. Simple approach
2. Brzustwoski and sommer approach
Also there is method for Flare KOD & Water seal drum sizing.
REgards,
Jatin
#6 Rush123
Rush123
  • 14 posts
Posted 11 December 2013 - 07:29 AM
There are several industry accepted softwares to do Radiation / Dispersion modelling.
Flaresim and PHAST come to mind readily.
Both should be able to help you calculate the min height required. Provided you already determined the max flow and flare diameter from Flarenet. Note: if you have a vent tip on this falre you would need to ask the vendor for the details on this. (Type of tip, F Factor, Pressure / Flow curve.)
Hope this helps.
#7 peteship
peteship
Posted 19 November 2014 - 03:04 PM
All of the above are good suggestions. I do flare design on a consultant basis, and would be glad to help you, e-mail pshipton@t-online.de
Pete
