Stainless Steel(304) Corrosion
Started by , Mar 16 2006 08:44 PM
Posted 16 March 2006 - 08:44 PM
Can any one make a comment for this kind of corrosion ,and which kind of material we can turn to to keep away from this kind of corrosion. The picture you see in the attachment is a corrosion within a distillation tower for ethanol fliud with hign chlorine oin.The red tuber you see is the place where the corrosion take place. inside it is a bit dark (light blue )pit.
Guest_Guest_*
Posted 16 March 2006 - 10:23 PM
Have you got the 'red tuber' analysed. Is it organic matter?
Posted 20 March 2006 - 01:48 AM
the red tuber on the surface of stainless steel is nothing but rust .
any one can offer me a detail analysis on this kind of corrosion i mean the process not the category.
hign conc.chlorine ion and lowest PH value .
Max Wall Temperature Stainless SteelStarted by Guest_ChristianColombini_* , 23 May 2024 |
Corrosion In RefineriesStarted by Guest_CHEMSTRONG_* , 19 Jun 2022 |
Refinery Corrosion InhibitorsStarted by Guest_CHEMSTRONG_* , 03 Apr 2022 |
Cost Factor/index Table For Mocs Like Carbon Steel, Glass Etc.Started by Guest_daraj_* , 29 Aug 2021 |
Corrosion Under Deposition At Trim Cooler Of Rfcc Main Fractionator OvStarted by Guest_Eric Nguyen_* , 19 Jul 2021 |
