To calculate pressure drop through expansions and contractions, you need to calculate the K value. To calculate the K value of expansions and contractions, you need to know the angle inside the fitting. The angle is not straight forward to calculate because at the entrance and exit of the fitting it is curvy.
Per page 121 of this book (full version downladable on Kindle for $51):
http://books.google....n angle&f=false
The angle of ANSI expansions/contractions should be calculated with this excel formula:
=2*ATAN((larger diameter-smaller diameter)/(1.2*Length per ASME B16.9))*180/PI()
Also, the Rennels-Hudson method is generally more conservative then the Crane equations; however, the two methods are in the same ball park for calculating K values for expansions.
